Group: DynoMotion Message: 10021 From: nbrobot Date: 8/22/2014
Subject: Cannot get dotnet homing to work
Hello,
I'm trying to run the dotnet homing example (see below) but nothing is happening on my step/dir stepper system (it is open loop - no encoder).  The RunAxisExample() works fine.
My limit switch is on IO0 and works fine (when I press the switch, a checkmark appears on the KMotion IO screen).  Then, I exit KMotion and run the RunHomingRoutineExample() and nothing happens (no motion of any kind).
        static void RunHomingRoutineExample()
            var axis = _Controller.GetAxis(0, "X");
    axis.Acceleration = 1000000;
   axis.TuningParams.Jerk = 1000000;
   axis.Velocity = 30000;
   axis.Enable();
   axis.CPU = 100;
            axis.HomingParams.SourceType = HOMING_ROUTINE_SOURCE_TYPE.AUTO;
            axis.HomingParams.HomeFastVel = 10000;
            axis.HomingParams.HomeSlowVel = 10;
            axis.HomingParams.HomeLimitBit = 0;
            axis.HomingParams.HomeLimitState = true;
            axis.HomingParams.RepeatHomeAtSlowerRate = true;
    axis.HomingParams.SequencePriority = 1;
            axis.DoHome();
Does anyone have any suggestions?
Thanks in advance!
Neville
